21 - 32 of 32 Posts
· Registered
Yea that’s true. The internet is a dual edged sword.
I read your earlier post from like 2020 and you were talking about a clanking sound you were getting. Did you ever figure out what that was just curious because i think im getting the same thing i think its coming from the area right where my primary tensioner is i bought a new tensioner and that arm block stop iv been hearing about that i plan on installing this week
· Registered
Discussion Starter · #28 ·
Well, I think it is my timing chain. Specifically I think the tension has failed, but I’m going to be replacing the timing chain and guides just as a preventative measure.
· Registered
I was just wondering because im actually having the same problem at the moment, i put in a new upgraded timing chain in last summer but i used a cheap primary tensioner i think thats what my property is so i bought a expensive tensioner this time and the stop block for preventive measures
Wood Font Table Audio equipment Wood stain
· Registered
Discussion Starter · #30 ·
Yeah.
I was just wondering because im actually having the same problem at the moment, i put in a new upgraded timing chain in last summer but i used a cheap primary tensioner i think thats what my property is so i bought a expensive tensioner this time and the stop block for preventive measures View attachment 43061 View attachment 43061
yeah, I think you definitely should get that new tensioner in. That’s something at least if you can afford it that I wouldn’t cheap out on is stuff inside the engine because I wouldn’t want to tear it apart to put another part in that I just replaced. That’s just me.
· Registered
Yeah.
Ya this new tensioner was $85 i think i payed like $17 for the last one so im hoping this one does better. I decided to get the block stop because i know these are interference engines so i would like to prevent my pistons fromvsmashing my brand new valves if i can incase the tensioner decided to brake
· Registered
Discussion Starter · #32 ·
Ok. Yea I definitely think that’ll work better for you.
21 - 32 of 32 Posts
