Got a 04 Intrepid 2.7 for free. Sometimes it goes into like a limp mode, doesn't shift out of 1st gear and I notice on the dash all the gear selector blocks are lit up. Checked codes on dash, what I got was P0700, P0113, P0123.
It doesn't do it all the time. I am mechanically inclined but I have never messed with these cars.
Any help would be great.
Thanks
Symptom:
P0113-INTAKE AIR TEMPERATURE SENSOR HIGH
When Monitored and Set Condition:
When Monitored: With the ignition on. Battery voltage greater than 10 volts.
Set Condition: The Intake Air Temperature (IAT) sensor voltage at the PCM is greater
than 4.98 volts. One trip Fault.
POSSIBLE CAUSES
IAT SENSOR VOLTAGE ABOVE 4.6 VOLTS
(K21) IAT SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
IAT SENSOR INTERNAL FAILURE
(K21) IAT SIGNAL CIRCUIT OPEN
(K4) SENSOR GROUND CIRCUIT OPEN
PCM
Symptom:
P0123-THROTTLE POSITION SENSOR #1 HIGH
Set Condition: Throttle Position Sensor voltage at the PCM is greater than 4.47 volts.
One Trip Fault.
POSSIBLE CAUSES
THROTTLE POSITION SENSOR SWEEP
INTERMITTENT CONDITION
(K22) TP SIGNAL CIRCUIT SHORTED TO (K6) 5 VOLT SUPPLY CIRCUIT
(K22) TP SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE
TP SENSOR INTERNAL FAILURE
(K22) TP SIGNAL CIRCUIT OPEN
PCM
P0700 is a generic transmission Fault code and indicates you need to get the underlying codes read. Either with a decent code scanner or at an auto parts store.
All indicators circles usually points to the TRS (Transmission Range Sensor) but not always. Without the specific Transmission codes it's a guessing game.
With your other codes above it's possible you have a wiring problem. Inspect the wiring at the back of the engine. You might want to try disconnecting and cleaning the C107/C108 connectors shown in the diagram below. Do this with the battery disconnected by taking the negative jump post cable off the top of the passenger side strut tower. Use Contact Cleaner to clean the connectors.
