Do they affect mileage? I've done research online and I've read that they negatively affect MPG and that it's recommended to "re-gear" the tranny, not sure what that means or how to do it.. Mind you, yes, they look good but it's like you're sacrificing drivetrain for looks.low pros on a LH make it ride like a kidney buster,,
The trans in the LH only has two gearing options - 3.66:1 (3.x), and 3.89:1 (2.7 and the Special (I think?)). If your overall outside diameter stays the same, then you shouldn't have to change gearing, except if for some reason there isn't enough grunt to get that much outer inertia spinning.Do they affect mileage? I've done research online and I've read that they negatively affect MPG and that it's recommended to "re-gear" the tranny, not sure what that means or how to do it.. Mind you, yes, they look good but it's like you're sacrificing drivetrain for looks.
