I have a 1995 Dodge Intrepid ES, and while driving the ABS light comes on and off intermittently. I only know of the Actron CP9449 that reads ABS codes, but they are only for OBD ll vehicles. My 1995 Dodge is a OBD I so the Actron will not work. Is there any other code reader for ABS OBD I?
I doubt it. You are probably stuck paying a shop to pull the codes. If you have a u-pull-it nearby you can probably get 4 used sensors and replace them until the light goes away. That is the long, roundabout way but it's a cheap fix.
But how do you know that its the sensors (just because they are the usual cause, this doesn't mean that it is his problem)
