I usually go til its snug. If you want a specific torque spec, maybe google has an answer or perhaps if you can find a 1st gen LH platform repair manual, that would be ideal.Does anyone know how much torque to put on spark plug tube nut? Thanks
I know on the 2nd gens there are 2 7mm bolts to remove and the whole headlight assembly come out. Then you can replace any bulb you need. The job takes literally 20 minutes or less for both sides.I don't mind removing a headlight to change a bulb, as long as I can easily do it. If I have to remove the entire front bumper and inner fender lining to do it, then it's a problem
