ok i have a 97 and i was wondering is there a site with the recalls for that year and my engine(3.5L).... also i have a few other questions...
the front window is there anyway to dimm that that with a tint so at night it not so bad... im sensitive to light....
Dodge logo- I've seen the huge dodge logos on back of a window on this site... were can i get one and whats the cost?
interior lights- where can i get some ones that are brighter and clear... so i can light out the car alot more then i stock?
front end alignment and Serpentine Belt-how much does it cost to get this fixxed??
ok and do the dealers cover any of theses to be fixxed???
like
Safety Recalls
1. 790 JAN 99 Recall - Fuel Rail O-Rings & Reinforcements
2. 712 APR 97 Recall - Passenger Air Bag Safety
because i can go down the list and pick out problems i have
Go to the posting "BRIGHTER INTERIOR LIGHTS" in the same forum. This may help with the interior light question you have. One answer in this link:
<RCE2WIN
Senior Member
Posts Per Day: 0.37
My Photo Gallery
If you want to brighten up the interior, switch to a hyper white 194 bulbs in the 4 overhead lights. I changed mine over and it makes a huge difference. You can use the colored LED's, but i've found it's a bit harder to read maps/directions/etc. with them. Change the fronts first and you'll see how much nicer they look and how more defined the colors on the inside are. Somone in here even rigged it up so he has colored ones run off a switch, so he is still able to use the stock lighting.>
TINT:
It depends on the State/County/Country you live in on the tint question on the windshield. Usually, with a doctor statement, you can get some tinting done. Check with a trooper or law enforcement in your area.
WINDOW DECAL:
Check around the sites and see if you can find a decal to your liking. Others on here may beable to help you on this.
GOOD LUCK
You need a four wheel alignment, which costs about $50 to $60. If you do the serpentine belt, then do the other AC belt as well. Parts are about $30. Labor should be an hour or less if you get some other work done.
Yes, I forgot the Alignment part. :blush:
DEFINITELY get the 4 wheel alignment. You should beable to buy a belt and do the serpentine yourself. If you are not comfortable with doing it, someone you know is probably knowledgable enough to do it. If not, yes, have it done at a shop. I am not sure of labor cost, as it depends on where you live and what type of shop you go to. If dealer, $$$$$$$$$. :eek:
Good Luck
