1 - 10 of 10 Posts
Many parts to sell- here are a few-call for more info or PM me- Karl 281-948-3610.Used Fan Assembly $25, NEW Harmonic Balancer-Dorman 594-183 $25, Used Fuel Pump /Sender $20, NEW Transmission Shift Solenoid #4539766/RL539766 $150, Almost New Radiator $50 only 3 months old, Nice Aluminum Wheels 4-$200, Reman. ECU $100 and more, contact me for what you need. Will ship to your location.
Discussion Starter · #4 ·
The pics are not as detailed as I would like them to be,if you want I could take some closeup shots. They are not perfect but would be better looking than steel wheels or nothing at all. New wheels run about $175 a piece off the internet. Thanks for looking.
What's the harmonic balacer for? 2.7 or 3.5?
Discussion Starter · #8 ·
The interior is a light Black or black gray. The harmonic balancer will work with some 2.7 , 3.5 and 3.2 engines. You need to verify thro a Auto Parts store or other source, the Part No. is Dorman 594-183 . It is brand new and still in its original box. The tires will come with the wheels at no additional cost. One tire is good for about 1/2 yr., two tires good for about 1 yrs.,last tire good for about 2 yrs.
...The harmonic balancer will work with some 2.7 , 3.5 and 3.2 engines. You need to verify thro a Auto Parts store or other source, the Part No. is Dorman 594-183 ...
I'm going to say it won't work for the 2.7, but is for 3.2/3.5. Do you know otherwise for sure? I've never seen one listed for the 2.7 other than OEM.
Discussion Starter · #10 ·
At the Dorman website it shows it fitting 1993-2004 yrs., engines 3.2 and3.5, on the Concorde, 300M, New Yorker, Intrepid, Prower and the Vision. Hope that helps, use your Auto Parts stores where your at to help you if your still in doubt or go to the Dorman website. They show a nice pic of it.
1 - 10 of 10 Posts
