Category: Domestic
Status: Clean Title
I have a 1999 Chrysler 300M for sale, in USA - Michigan.
Mileage: 190,000 miles
VIN: 2C3HE66G9XH790517
Engine Size: 3.5L
Asking price is $3000.00
Any interest in my 300M?
Contemplating selling my 1999 Chrysler 300M because I do not drive it much anymore... car has 190,xxx miles
Car has a few upgrades, 03-04 tail lights, TSW 17" wheels, Chrome shift knob from 300M Special Edition, clear corners, woodgrain dash upgrade and steering wheel, 3.89 gears also has slotted and cross drilled brake rotors
The car received a new engine in 2010, as well as a used transmission that had 50K on it. I believe the car had 169,xxx miles when I replaced engine and transmission
I have kept up with the maintenance, on this car replacing the following over the past year or 2, I have receipts for all parts.
Brake Rotors (front and rear)
Organic brake pads (front and rear)
driver side axle shaft
passenger side axle shaft
front driver side brake caliper
front passenger side brake caliper
Driver side wheel bearing
Passenger side wheel bearing
Driver side inner tie rod
Passenger side inner tie rod
Driver side outer tie rod
Passenger side outer tie rod
Front struts
Front strut bearings
Front coil springs
strut rod bushings
Sway bar end links
Serpentine belt tensioner pulley
Remanufactured ECM
Remanufactured TCM
Radiator
Battery
Serpentine drive belt
V-belt (AC only)
Cam sensor
Last summer I pumped out the old Pag oil and refrigerant and recharged the system with new pag oil and R134.
The bad
Car has heated seats (driver side stopped working, passenger side works fine)
Chrysler amp took a crap and thought the factory infinite system sounded like garbage any way, so I upgraded the head unit to a Pioneer MP3 head unit and bypassed the amp.
Moon roof needs some attention (doesn't leak but it does not open like it should)
passenger side dash has some cracks in the vinyl
cracked windshield
passenger side front window regulator needs replacing
Fog lights are not working
Body is above average for a 12 year old car never been in any accidents I have owned since 2002.
Discussion Starter #2
$2800 obo
Car now has 195,000. $2200 obo
$2000 ?
Open to offers
Sold
