I have a 99 Intrepid that will turn over but won't start. It acts like it isn't getting any fuel or spark. All fuses are ok. The fuel pump runs when the key is turned on. The car will try to fire when starting fluid is sprayed in the air intake so it seems to be getting spark. I tested the fuel pressure where the line connects at the tank and got about 50 psi. I'm not sure what to try next.
Did you ever figure out what was going on with your intrepid. My daughters is doing the same things. We finally got it to fail at a mechanic shop today and they are now looking at cam/crank sensor or computer.
Sounds like the OP's car possibly had low fuel pressure. All the tests would need to be done to verify spark, fuel pressure, timing and injector signal, and troubleshoot whatever is not present.
Crankshaft sensor is a relatively common failure, they usually wont even fire on either in that case though.
