1 - 2 of 2 Posts
I've got a 1999 Intrepid with 2.7L and 240,000+ miles. This winter it started blowing hot air only at about 1500 RPM or higher. At idle, it blows cold air.
I'm assuming that perhaps the heater core might be slightly plugged, but it's just a guess. Based on the info on alldatadiy.com, it looks like replacing the heater core on this car is a real chore and a half.
Anyone have any ideas on whether my theory is accurate, and if so, best way to proceed short of replacing the heater core?
Thanks,
Jason
Is the car running at normal operating temps on the temp gauge? Have you checked the coolant level to verify it's full? Depending on what temp it's running at, it could also be as simple as a thermostat that's sticking. Before replacing the heater core, you could try to flush it. Remove both heater core lines and force water through one end. See what comes out.
1 - 2 of 2 Posts
