1 - 20 of 23 Posts
I've posted that site many times. Thats where I bought my clear corners.
One wasnt sealed very well, so it keeps getting condensation in it. But one of my stock corners had the same problem...
Warlord187 said:
The guages I've heard are cheap (quality wise) and just plain suck.
Not true. Turbo has them and hasnt had a problem yet. (that i know of)
No, he was right. The guages are for 2nd gen. The corners are for 1st.
I have also heard about problems with thier gauges.
well.. I just orderd the clear corners... do you know where they leak in?
So I can preventitively seal up those cracks?
Maverick9110E said:
try using a clear waterproof epoxy from a hardware store that should work good.
Rofl... should I just dip the whole assembly in it? or should I target just an area? (this is an attempt at humor)
The area where the clear plastic meets the white plastic. Just put a line of silicone along it, and then wipe off the excess with your finger. Wipe off your finger with a paper towel (dont wash first!).
Might want to seal up the headlights too while your at it. Same area.
Warlord187 said:
Really? Intreper had them and they didn't work right and were built shitty.
You got it brother! I installed them and the transformer blew after driving around with the gauges on for about an hour. It took me for ever to get them replaced by PRO CAR PARTS. Their customer service sucks @$$ in my opinion. Not to mention they barely speak inglish. I still have the new set they sent me out and will probobly never install them.
Well, if Turbo was ever around he could chime in, but they looked good in his car. I dont know if they have still held up or whatnot.
I got a vid of his in his car.. they looked quite sweet
The thing i never like about clear corners on any car is how they look so diferent than the headlight. They always look too clear and cheap looking. If they sold a clear corner that was the same (looks wise) as the stock corner light except without the amber in it i would buy it.
my clear corners will match my clear headlights just fine (both will be within 1 year new.....)
1 - 20 of 23 Posts
