I have been reading the manual specifically page 9-41 and it gives the two bearing sizes 0.025mm (0.001in.) and 0.250mm (0.010 in.). I am trying to figure out what size bearing my car needs. I picked up both sizes and a plastigage but the manual does not say what the clearance should be with the bearing installed.
The manual seems to indicate you use the plastigage to check the rod bearing clearance but then it never indicates what the bearing clearance is unless I am overlooking something.
HELP!
Craig
You don't say what year FSM, but I assume 2002?
Look on pages 9-17 thru 9-20 for a fairly complete list of specifications.
