I just found out the problem with my 2.7, spun #6 and #3. Although #3 isn't as bad as #6, if that is possible. Just checking if I can save this thing, so I need the specification.
#6 53.22
#3 53.44
#6 53.22
#3 53.44
Are you looking for the connecting rod journal specs for the crank?
If so= 2.1060-2.1067inches or 53.4924-53.5102mm
If those are your measurements above ,looks like you might shop around for a crank kit. (or a replacement)
Oh sheisse!
Thanks for the info lex, I am hoping to find one at work and get it ground :)
Pin bearing or Pin journal = Connecting Rod Journal
