I have just about everything that I need to complete the swap. However, does anybody know which p/s hose I will need? Is it the pressure hose or the return hose and which heater hoses will i need, the straight or molded?
Hi,
I've done the swap you're doing.
I got the 3.2 engine with the PS attached- the junkyard people cut the hoses so I replaced both.
As for the heater hoses, I got the ones for the 3.2 engine- molded.
Good luck!
Peter C. Sessler
You just need the short steel S-shaped tube from the pump to the hi pressure line, the reservoir, and the return line hose from the pump to the reservoir.
