2004 Dodge Intrepid SE. I bought it a little over a month ago, but no warranty.Just over a week ago the car would suddenly vibrate as if it were to shut off. Just within the past few days, the engine vibrates like crazy every single time that its on. Whether I have it on park or Im driving.
On Friday the car was checked and there were two codes given to me due to the engine light staying on. It said that the SYSTEM WAS RICH in Bank #1 and Bank#2.
Yesterday I changed the spark plugs because they were old and on some there was no current running through. (that is now fixed)
I changed the elbow on the Idle hose due to a tear, and also the PCV Valve and hose. I took it for a drive yesterday and for about 6 minutes the car ran smooth and with all the power that it has, no vibration. Then suddenly it began to vibrate again. It hasnt stopped and now I have the following codes:
P0172 :SYSTEM TOO RICH IN (BANK #1)
P0508:IDLE CONTROL SYSTEM CIRCUIT LOW
P01103:IAT SECTOR #1 CIRCUIT HIGH INPUT
P0108: MAP/BARO CIRCUIT HIGH INPUT.
I was told by someone that it might be the Gasket. so Im looking at a minimum of $250 plus a $89 diagnostic test.
Christmas is coming and the last thing I want is to not have a car to go to work in and make money to support my 3 babies and wife.
Please help.
yep....it may look to be a bad gasket at the intake plenum or lower intake throwing all those codes ..... little tough to believe all those sensors went out at the same time
Do I go straight for the gasket? If not, how can I check the lower intake plenum regarding it throwing all these codes?
Thanks.
yippee ki yay
Thanks.
IMO what you have is a vaccum leak causing all them sensors to go off and causing the car to run very rough......can you get the job done cheaper them $250....yes.
you can change this out yourself....it's not diffcult to do and would probably take a total time of a couple hours if your working slow to do both gaskets.
It could be that the bolts for the upper and lower just need to be retorqued to the listed setting of 105 in lbs......i tend to go to 115 in lbs on my settings.
i have an idea for you, its worked for me in the past....
start the car up
pop the hood
take a can of some "gumout" carb cleaner and spray it around the base of the of thhe intake plenum and if the RPMs fluctuate at all theres your issue the intake gasket.....
i hope this works for you
