1 - 10 of 10 Posts
the car just went into limp mode with the PO731A code. it has only 36,000 miles on it. the obd reader says gear 1 incorrect ratio. the speedometer or odometer does not work and it seams like the trans is stuck in second gear. suggestions? thanks :kitty:
Speedometer not working specifically points to bad output speed sensor.
thanks all. it was the output speed sensor. i took it to local little trans shop, "shiftsright". the guy is awesome won't rip you off. have to help the little guys out too. only charged $75. now back to :riptires: ,well, not really. i save that for my 65 barracuda. thanks again. jeff
How many bad speed sensors are there going to be this week? Mine and at least 4 others that I know of.
Funny you would mention that... It does seem as though they like to fail in groups. We haven't done hardly any all summer then, wham!
Perhaps as the sensors age, they are eventually marginal at moderate temperatures and over the edge at lower temperatures - then when winter hits, suddenly many don't work. Save those for summer use only. :)
1 - 10 of 10 Posts
