My camshaft sensor I can't get it out with taking off the camshaft cover Wich looks pretty involved is the only way
You'll need to at least loosen the bolts holding the Upper Intake on so you can tilt it some to remove the Cam Sensor. Preferable to remove the Upper Intake (Plenum) and use new gaskets and re-install. Your choice.
Here's the relevant info for the Intake manifolds on the 3.2/3.5 engines.
