Soooo Pissed can't type, first of all was replacing upper and lower ball joints, uppers no problem, lower 5 hrs later finally removed the drivers side, now I can't get the new one pressed back in !! I went as far as removing the Shock, Sway bar, both bolts Going to the frame, and I believe it's called the Torsion bar, well the bolt in the back. I was going to remove everything so I can take this F--King thing to work or a shop and see if they can press it in, now I can't remove the torsion bar.. The bar I'm referring to is the one with the octagon head on it up near the frame.. Any help would be greatly appreciated..
get off my lawn
oh , they are a *****, I just never removed the bar, but , my ball joint press is extra heavy duity,, wish I had a answer for you
