1 - 9 of 9 Posts
My 300M quit on me as I was driving to gas station,it was driving ok then it started to run like it was not getting power,sluggish and jumpy bucky like.........anyway I had it towed to a mechanic shop,he scanned it and it showed that EVERY sensor was bad along with 16 plus codes.motor is good sensors are less then 9 months old brought brand new when Engine was replaced in August of 2019,new water pump and timing belt alone with new radiator and thermostat...my question is would a fualty engine wiring harness shorting out cause the scanner to show ALL The Sensors being bad and the codes and cause it not to start?
The sensors are powered by a 5 volt sensor bus off the PCM. Probably one sensor has failed shorted and is pulling the 5 volt bus to ground - hence no sensors can work. Historically, the a.c. pressure transducer is known for being the one that has failed and is shorting out the sensor power bus. Disconnect the a.c. pressure transducer connector and see if everything else comes alive. You can check for 5 volts on any sensor connector to see if the 5 volts is there. See FSM section 8W for wiring diagrams and connector pinouts.
If that sensor is the problem, it is easily replaced - it screws into a schrader valve fitting, so R&R’ing it is a matter of unscrewing and re-screwing without discharging you’re refrigerant.
If that sensor is not the problem, check other sensors by disconnecting each one until your 5 volts comes back.
Ok will do, but one other thing the wire that goes to bank 1 rear on the driver side has either a short or open becuase when plugged in it sets a code stating that the heater something is not functioning even after i replaced the o2 sensor
Bank 1 O2 sensors are on the passenger side same as Cylinder Number 1 on the engine. Bank 2 is the Drivers side.
1/1 and 2/1 are the Upstream sensors mounted on the exhaust manifolds before the catalytic converter. 1/2 and 2/2 are the downstream sensors mounted after the catalytic converter.
What's the code number(s) that you have?
These are the O2 Heater related codes.
P0030 O2 sensor 1/1 Heater Circuit
Shorted condition detected in the oxygen sensor heater
element control feedback sense circuit.
P0031 O2 sensor 1/1 Heater Circuit
P0036 O2 sensor 1/2 Heater Circuit
P0037 O2 sensor 1/2 Heater Circuit
P0038 O2 sensor 1/2 Heater Circuit
P0043 O2 sensor 1/3 Heater Circuit
P0044 O2 sensor 1/3 Heater Circuit
P0050 O2 sensor 2/1 Heater Circuit
P0051 O2 sensor 2/1 Heater Circuit
P0052 O2 sensor 2/1 Heater Circuit
P0056 O2 sensor 2/1 Heater Circuit
P0057 O2 sensor 2/2 Heater Circuit
P0058 O2 sensor 2/2 Heater Circuit
P0130 1/1 O2 Sensor Heater Relay Circuit
An open or shorted condition detected in the ASD or CNG
shutoff relay control ckt.
P0131 (M) 1/1 O2 Sensor Shorted To Ground
Oxygen sensor input voltage maintained below normal
operating range.
P0132 (M) 1/1 O2 Sensor Shorted To Voltage
Oxygen sensor input voltage maintained above normal
operating range.
P0133 (M) 1/1 O2 Sensor Slow Response
Oxygen sensor response slower than minimum required
switching frequency.
P0134 (M) 1/1 O2 Sensor Stays at Center
Neither rich or lean condition is detected from the oxygen
sensor input.
LH ELECTRONIC CONTROL MODULES 8E - 13
POWERTRAIN CONTROL MODULE (Continued)
(M) Malfunction Indicator Lamp (MIL) will illuminate during engine operation if this Diagnostic Trouble Code was
recorded.
(G) Generator Lamp Illuminated
GENERIC
SCAN TOOL
CODE
DRB SCAN TOOL DISPLAY DESCRIPTION OF DIAGNOSTIC TROUBLE CODE
P0135 (M) 1/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0136 1/2 O2 Sensor Heater Relay Circuit
P0137 (M) 1/2 O2 Sensor Shorted To Ground
operating range.
P0138 (M) 1/2 O2 Sensor Shorted To Voltage
operating range.
P0139 (M) 1/2 O2 Sensor Slow Response Oxygen sensor response not as expected.
P0140 (M) 1/2 O2 Sensor Stays at Center
sensor.
P0141 (M) 1/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0143 1/3 O2 Sensor Shorted To Ground
operating range.
P0144 1/3 O2 Sensor Shorted To Voltage
operating range.
P0145 1/3 O2 Sensor Slow Response
P0146 1/3 O2 Sensor Stays at Center
sensor.
P0147 1/3 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0151 (M) 2/1 O2 Sensor Shorted To Ground
operating range.
P0152 (M) 2/1 O2 Sensor Shorted To Voltage
Oxygen sensor input voltage sustained above normal
operating range.
P0153 (M) 2/1 O2 Sensor Slow Response
P0154 (M) 2/1 O2 Sensor Stays at Center
sensor.
P0155 (M) 2/1 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
P0157 (M) 2/2 O2 Sensor Shorted To Ground
operating range.
P0158 (M) 2/2 O2 Sensor Shorted To Voltage
operating range.
P0159 2/2 O2 Sensor Slow Response
P0160 (M) 2/2 O2 Sensor Stays at Center
sensor.
P0161 (M) 2/2 O2 Sensor Heater Failure Oxygen sensor heater element malfunction.
Got another problem something is draing my battery when it is turned off,did the diode test with all the wires disconnected from the alternator,red lead to post and black lead to case reading showed 1 or OL and red lead to case and black lead to post reading showed 1269 millivolts, isn`t that like 1.2 volts would that be enough to kill my battery after a day just sitting and not starting? what is the range for the voltage reading ?
Your test shows that the diodes are not shorted.
1 - 9 of 9 Posts
