I have a 2002 300m with 3.5l. The skim module got damaged. I have no power to the starter. I tested the stater its good. When you put the key in it and turn it to on the light would go out then turn back on. I replaced the skim module with a used one. Now you put the key in it and turn it to on the light will blink. What cars could i get the keys, skim module, and the computer from to make it work.
You got to get a another skim,key and PCM all from the same car of 2002 to 2004 preferred from a 300m to make it work or any other skim, grey key equip vehicle intrepid,Concorde from 02 to 04 for the meantime so you will be able to drive your vehicle
Or get the car towed a dealer and have them program your current keys and PCM to the "new" SKIM module. Might want to call and see what the local Dealer will charge or even if they'll do it.
