Has about 175k on it. Been a great car for me, was going to give it to my daughter when she turns 16 in a few months but she complained it is too big, kids these days, complain about a free car. Anyways, the good:
First thing I did was timing belt, water pump, drive belts, radiator hoses, done plugs twice on it since I have had it.
Front brakes a year ago, new pads, rotors, calipers, and hoses. ALL metal brake lines are new, all the front stuff is factory prebent Mopar, the long ones going to the back we made. The entire front suspension is new, monroe ecomatic quick struts, I retorqued them so no clunking, control arms, strut rods and bushings, sway bar links and bushings, Dorman cradle bushings, the rods, etc. Has new ac actuators and blower motor resistor module. It has all LED lights on the outside except the rear parking/stop lamps, those wouldn't work right for some reason. The headlamp low beams are 3 sided Starnill and they are AWESOME, paid like $80 for those like a year ago but I think they are cheaper now. The fogs are cheap LEDs that don't put out much light but just put them in to match color. Front turnsignals are switchbacks, light up white but blink yellow so the whole front end is white, I probably have about $200 worth of exterior LEDs on it. It has a double din it it which I'm going to keep, has a gap under the radio that I didn't finish, you could finish it with a piece of plastic or leave as is. It's plastidipped. I have the stock bezel to go along with it, but ill leave the double din bezel in it too. It has an Advance Auto AGM under the hood. New Mopar O2 sensors except 1, I forget which one. Tires are good, 2 Continental and 2 Michelin, had 4 Continental but I waited too long between them, doing the front suspension, and getting a 4 wheel alignment so chewed 2 up. Grille is plastidipped. Put in a Mopar shock sensor that added to the factory keyless. Has a fullsize chrome spare. One of the ac hoses is new. Has the 'best' factory amp in it. Have a few odds and ends that come with it, extra set of sail panel tweeters, 160a alt...
It shifts fine, has plenty of power, idles smooth as butter. Doesn't leak a drop of anything last I looked, I wouldn't be scared to drive it cross country.
I'll leave a spot here cause I'm sure I'll remember more. Has alot of new parts on it, was a one owner car when I got it as far as I can tell from history.
The bad:
Needs exhaust, the mid muffler split, down pipes look good, so from the down pipes back. I figured out all the part numbers to put a special dual out exhaust on it I'll give you, I think I figured it to be between 2-300 to do a special dual out, I was gonna put dual tips so it looked like quad exhaust.
The evap is leaking, the parts to do it come with the car, new evap, expansion valve, and heater core while you are in there.
The drivers seat heater doesn't work.
The ATC head display doesn't work but comes with a rebuilt dual color one from M-pressive.
I clipped a pole last year and smashed the fender and headlamp, I put on a brand new Mopar fender, it's just black primer, and a brand new Mopar headlamp. The gaps aren't perfect but I'm not a body guy and I'm sure some tweaking and it will be ok. Front bumper has some paint rubbed off. Grille is plastidipped black. Has some stone chips on the hood and minor scratches and dings, not bad for a 175k car.
The moon roof wont close unless you hold a guide piece down, I can hold it down and close it while driving, it's that simple, the vent feature works fine.
Has the litter tick on start up, never fixed it cause it doesn't bother me, goes away after half a second.
I'll start at $2200 OBO
Not sure what to ask for it, it really is a nice car, I'll consider any reasonable offers. Soon here I'm gonna get tired of looking at it sitting and spend a day doing the evap, that really is the only reason I don't drive it every day, the exhaust is cake to do. Obviously I'll drive to meet, I'm about an hour south of Carlsile, located at 21716 presently.
Sent from my SM-G930P using Tapatalk
Discussion Starter #2
Sales codes, sorry it's all jumbled, just the way it copied and pasted
Here's a list of the factory options, sorry if it reads funky, I copied and pasted
AJFSRemote/Illuminated Entry GroupAPASMonotone PaintBCSSBattery Run Down ProtectionBNMSTraction ControlBR3SAnti-Lock 4-Wheel Disc BrakesCF4SChild Seat Upper Tether AnchoragesCGDSFront Height Adjust Shoulder BeltsCGWSNext Generation Front Air Bags**CG6SCenter Rear 3-Point Seat BeltCHNSTrip Comp/Garage Open H/Liner ModCKDSFloor CarpetCKMSCargo Compartment Dress-UpCKRSCargo NetCK7STrunk Pull-Down StrapCLESFt/Rr Floor Mats w/Driver Tie-DownCVWSLeather Wrapped Shift KnobDGBSAll 4-Speed Automatic TransmissionsGAMSSolar Control GlassGBCSFront Rear Solar Control GlassGFASRear Window DefrosterGXTSRear Door Child Protection LocksHABSAir Conditioning w/Auto Temp ControlHGLSPremium Insulation GroupJAASInstrument PanelJA2SInstrument Cluster w/TachJGGSAnalog ClockJHASVar Intermittent Windshield WipersJJBSDual Note Electric HornsJKASLocking Glove BoxJKKSInside Emergency Trunk Lid ReleaseJLKSPremium Body ControllerJPCSPower Trunklid ReleaseJPDSPower Windows, Driver One-TouchJPHSSpeed Sensitive Power LocksK5USDEEP SAPPHIRE BLUE P/C Molding - SK8USDEEP SAPPHIRE BLUE P/C Molding - BLBCSGlove Box LampLCFSFront Door Courtesy LampLDCSTrunk LampLMGSAutomatic HeadlampsLMTSHalogen Projector w/Delay HeadlampsLNJSFog LampsLSASSecurity AlarmMHASBlack Windshield MoldingsMMFSDay Light Opening MoldingsMNKSBody Color Door HandlesMZ6SConcorde Limited BadgeNELSDual Bright Exhaust TipsNF3S17 Gallon Fuel TankNHMSSpeed ControlQBWSDeep Sapphire Blue Pearl CoatRDLSIntegrated Window AntennaRDZSSteering Wheel Mounted Audio CtrlsSBCSSpeed Sensitive SteeringSDGS4-Whl Indep. Touring SuspensionSUASTilt Steering ColumnTR1SP225/55R17 BSW AS Touring TiresWGWS17 Aluminum Chrome Clad WheelsXGASFront/Rear Climate Control OutletsXSLSBrake/Park InterlockXVMSOwner's ManualYAASBuild To U.S. Mkt. Specifications1AASU.S. Dealer Retail133SZone 33-Philadelphia5ILSLH-Vehicle Family594SVehicle Order Tracking6USSU.S. Specifications Label639SPennsylvania Ship to State Code939SPennsylvania Sold to State CodeOptional EquipmentCodeDescriptionCodeDescriptionCodeDescription*TLLux Leather Trimmed Bucket Seats-L2Light TaupeAFFLuxury GroupARFRadio Cass/4 CD/Amp,11 Infinity SpkrBAFP130 Amp AlternatorBC2P600 Amp Maintenance Free BatteryCDLPManual Driver Lumbar AdjustCDMPLeather Trim SeatsCFWPRear w/Trunk Pass-Thru SeatCGSSupplemental Side Air BagsCJ1PSupplemental Frt Seat Side Air BagsCSLPRr Seat Armrest w/Storage CupholderCSRPPassenger Assist HandlesCSYPGenuine California Walnut Wood TrimCUFPFull Length Flr Console w/CupholdersCUNPOverhead ConsoleDGX4-Speed Automatic TransmissionDLBP2.5 Overall Top Gear RatioEGG3.5L V6 High Output 24V MPI EngineGNCPSun Visors w/Illum Vanity MirrorsGNTPRear View Auto Dim MirrorGNZPAuto Dim Exterior Driver MirrorGUDPPwr Heat Memory Folding Auto MirrorsGWAPower SunroofGXCPCentral LockingGXRPKeyless EntryGXXPSentry Key Theft Deterrent SystemJA6PElectroluminescent Instr ClusterJCBP120 MPH Primary SpeedometerJFHPTachometerJKWP12V Center Console Power OutletJPMPHeated Front SeatsJPRPPwr 8-Way Driver Passenger SeatLACPIlluminated EntryLAZPVehicle Information CenterLBGPFront Reading/Map LampsLBHPRear Reading/Courtesy LampsLETPTrip ComputerLEWPRadio/Driver Seat/Mirrors MemoryLEXPAuto Adjust in Reverse Ext MirrorsNAS50 State EmissionsNBVPLow Emission Vehicle (LEV)NMDPStandard Duty Plus Engine CoolingPBWDeep Sapphire Blue Pearl CoatRBBPAM/FM Cass Radio w/Changer ControlRCPP11 Infinity Speakers in 9 LocationsRDSP360 Watt AmplifierRDWP4-Disc in Dash CD ChangerSCWPWood/Leather Wrapped Steering WheelTBYFull Size Matching Whl Spare TireTZHPMichelin Brand TiresWLZCAll Aluminum WheelsXGDPUniversal Garage Door OpenerYEPManuf Statement of OriginYGCA7 Additional Gallons of GasZCEPSpring - Left FrontZCVPSpring - Left RearZREPSpring - Right FrontZRVPSpring - Right Rear2DJACustomer Preferred Package 2DJ26JCustomer Preferred Package 26J3VVACustomer Preferred Discount
Make me some offers, soon it goes to the junk man! Just put a battery in it (I haven't driven it in a couple months, it was deader than a door nail) and it still runs and drives great! I aired up the tires and checked the oil, it doesn't leak a drop! If for some reason I don't respond on here email me [email protected]
For some reason I don't always get emails that the thread was updated
