1 - 10 of 10 Posts
I just replaced all of my brake pads and rotors
used Brembo rotors and Hawk ceramic pads
followed the instructions for burnishing/ bedding the pads and then let them cool
the rear passenger wheel has been making noise since i installed them, and it seems to be getting worse
it makes no noise at all though if i go in reverse and then stop
there appears to be a ring on the rotor of unusual wear, but what can i do about it?? the noise is really annoying
some pics of the rotor..
http://i3.tinypic.com/11ad05z.jpg
http://i3.tinypic.com/11ad84n.jpg
http://i3.tinypic.com/11ad9qf.jpg
thanks for any advice
get off my lawn
sounds like you have a piece of hardware misplaced and scraping the rotor,, or if the pads are semi metalic ive seen them "hardspot" to where they will chew up a rotor
did all of the work on saturday (5 days ago) with my dad
it only makes the noise when i apply the brake, but the weird thing is that if i'm going in reverse about 15mph, I can hit the brake and I get no noise at all
my trep is doing something similar to that too (right rear as well) since I did the brakes.
i retract my previous squealing claim.... it is definitely a scraping noise... i listened more attentively this afternoon
i'm just gonna have to take it apart saturday and figure out what the heck is wrong
My Intrepid did that when I got new rotors and pads - i had tires plus check them over two seperate times and they seen nothing wrong. Fortunatly it did go away after a while - but i hated every minute of it...
problem solved.... the sensor clip was dragging, i bent it by hand away from the rotor.... i don't know how it got to that position in the first place... ??
thanks for all input
1 - 10 of 10 Posts
