I have an 02 intrepid, the engine compartment was pretty gunked up so I washed it out with a garden hose and some degreaser and now the check engine light is on and it's sputtering and acting like it wants to die. Any ideas?
first thought is let it dry, 2nd thought is what codes does it throw with the check engine light - assuming that there is a misfire code and probably something else if the problem was caused by water/solvent getting past a harness connector.
Not sure on the code. I let it dry for a few hours and it seems to run fine. When I kick the AC on it start to drag a little but doesn't die. The check engine light is still on though.
