21 - 30 of 30 Posts
· Woober Goobers!
I'm thinking you still have a fuel pump problem. You'll need to check the fuel pressure with the appropriate gauge, etc. I'm thinking it's low pressure also.
· Woober Goobers!
Do what Dan indicates in post #12.
· Registered
It sounds like you might have two issues. One related to sensors (cam or crank) and one related to fuel delivery.
For what its worth I had an intermittent no start issue but not as frequent as yours. I also had an occurrence of P0340 (camshaft position sensor circuit). I replaced my crank sensor with an OEM one. Note that an intermittent crank sensor can trigger a P0340. I haven't had a no-start issue for almost three weeks now. My fingers are crossed.
· Registered
Did you ever figure this out? I have a 2903 Intrepid, 40,000 miles (it was my late uncle’s and he didn’t drive much). I’m having the same issues. Replaced crankshaft sensor and about to replace cam sensor when I found this thread.
21 - 30 of 30 Posts
