I want to swap out the Cluster for the 2nd gen one, My friend said that he couldn't use it cause of the missing pins that holds the gauges. So I am in the process of fixing that and want to use it... Anyone Know if it will work or if I have to rewire for it???? All help is welcome.
Dain bramaged
will not work..
2g car's keep the milage in the BCM for starters.. I also believe the information Bus is different..
yea exactly....the BCM messes up alot of things that would make any of the eletronic parts in the cars swapable. The whole system between the two generations make it totally different.
J
Guest
Veeborg is right.
I stand witness that almost no electronic components from 2G are swappable into our 1G.
Bus was changed from ISO to PWM18xx.
And then 3G came (2004+ model years,) and bus got changed again, to CAN.
