41 - 53 of 53 Posts
The 2000 manual opens jumbled for me. Where is engine cooling and 3.5 engine? The paper FSM #s are either not there or overlapped with others.
Help please.
Goes from zero to two(#1 not there) An index for the 2000 would be great! Could someone email the index, 3.5 engine and the cooling sections to me?
There is no ELH_1, so that's normal.
ELH_TAB is your index. There's no alphabetical index. If you want one, buy the manual.
3.2/3.5 starts at 9-74. Cooling system is ELH_7.
It's all there, so if you're missing pieces you either didn't download it all, or you somehow messed up unpacking the files.
It's probably me. I'm not very used to that setup. I usually need intructions for extracting. Only recall doing that once before. I'm missing quite a few and have doubles of others.:banghead:
I know it's been a while since these links were posted, so it's no surprise that they aren't working now. Is there a way to get an updated link? I need to replace my trans solenoid.
Thanks so much for your time.
See if this works. I extracted section 21 for the transaxle from the 2002 FSM.
You may right click save as or click on it to open.
2002-2004 FSM (No 2.7 section)
They will be required to have or download Adobe Acrobat.
Index:
http://www.dodgeintrepid.net/manuals/02lhe/02lheIndex.pdf
Part 1
Chapters 01 Thru 8W-47
(29 MB)
http://www.dodgeintrepid.net/manuals/02lhe/02lheA.pdf
Part 2
Chapters 8W-48 Thru 25
(29 MB)
http://www.dodgeintrepid.net/manuals/02lhe/02lheB.pdf
Complete Manual
(56 MB)
http://www.dodgeintrepid.net/manuals/02lhe/02lhe.pdf
2001 FSM
http://oskin.ru/chrysler-dodge/manuals/Service Manuals/2000_LH_LHS_300M_Concorde_Intrepid/
(Please let us know if any of the links dont work for you)
Links dont work. I need the wiring diagaram where I'm supposed to tap into my 03 es bcm so I can do an autostick conversion
Does anyone have a factory service manual for a 99 dodge intrepid es?
Not in PDF format. I do have a full set of the 1999 LH paper manuals. $55 shipped in the ConUSA
41 - 53 of 53 Posts
