1 - 2 of 2 Posts
I have a 2003 dodge intrepid sxt.. I know that the thermostat housing bolts are 10mm..But I don't know what the dimensions and the lenght is..
M6x1 thread. Sorry - don’t know the length - the parts pdf’s don’t say. You could measure the thickness of the housing plus gasket, and get bolts that are about 10mm longer than that. Problem with aftermarket bolts is they come in pretty large length increments. Probably want at least 8 threads (8mm) minimum thread engagement (to avoid stripping the threads when tightened), but of course it can’t bottom out in the hole, so you may have to buy long and cut to length. Also may see if dealer parts can look up length - maybe can sell you the exact bolt.
1 - 2 of 2 Posts
