i would like to find an inexpensive upper intake plenum assembly form a salvage yard to install on my 2000. I would prefer the electric valve actuators instead of the vaccum operated ones. What years will work on my 2000? Also, do all HO intakes have both the short runner valve and the manifold tuning valve? Do some years only use the SRV, if so which is better?
Your pcm wont operate the electric actuators,you will have to stay with the vacume. They switched in the 02 model year along with the wiring harness and pcm's.
All the HO's have the 2 valves, I believe the 3.2 plenum is the same from what I have heard.
