cant figure out why my idle is jacking to 3k.
half the engine is disassembled, no power steering, no alternator, no intake, not even 1 o2 sensor plugged in.
my thoughts on the cause are:
pcv valve not installed.
IAC stuck.
please advise.
PCV valve not installed would cause a huge vacuum leak, almost totally bypassing the throttle body idle air control. Start there.
"Half the engine disassembled" could be the issue too; if there is something else that could cause a vacuum leak...that is literally the only thing that will cause an extremely high idle...
