:auto_06: Does anyone know how to get the heated seats from a 300m to work in an 98 Intrepid? I'd greatly appreciate the info :)
Ken
Should be plug and play, but if you do a search and look at posts older than 45 days I know the subject has been discussed here before... At worst case you will just have to run an extra line for the heater.
Or, I'm sure somebody else will post additional info for you.
not plug and play, there are 2 wires that go to your bcm which are the power and pci wires i believe the power is blue/white and the pci is violet/yellow. also make sure you connect all the wires from the passenger seat to the drivers seat color for color. then take those 2 wires i mentioned about and tap into your otis wires, (or if you want to make it look stock then you need to go behind the bcm and tap in there.
Yeah
Yeah...this site is da bomb!!! And quick replies too!!
