1 - 11 of 11 Posts
I can only find sway bar bushings for 1.00" and 1.06" sway bars. Mine is 1.15"
Any ideas? I checked rockauto and advance.
That's all aftermarket offers.
Is your actual sway bar 1.15"? If the 1-1/16" bushings won't compress down, you'll have to drill them out.
Are the correct OEM ones still available? I heard they're even subsitituing the wrong sizes for those now.
1.152 was my caliper reading... I don't think they are really that bad yet but I'm changing struts and would like to get them while I've got everything apart.
Since I hate it when people don't post their work-around to problems like this one once they figure it out I will post mine with the intent it will help someone down the road.
I bought the 1.06" Monroe brand bushings ($18.99) from Advance Auto Parts. Picked up in store after buying online using a discount to get 3 over-sized oil filters for basically free with the purchase.
I stuck one side on so far and it seems to work just fine.
Did you use any grease on the bar/bushing? If so what type was it?
No, should I have? I've got a grease gun handy.
a silicon type lube is best for this,, wont eat polly or rubber
Ok, thanks
That's what I heard/read. A silicone based or synthetic grease. Something like the "Super Lube" brand that you can get at Ace. I also think the auto parts stores have small packets of that stuff on the counter along with the packets of anti-seize compound, etc.
Yeah, I will pick some up. I already put the one side back together so it likely wont get it.
Discussion Starter #11
I couldn't find any synthetic stuff so I just used white lithium grease that the parts guy suggested. He seemed to know his stuff so I went with it.
1 - 11 of 11 Posts
