1 - 20 of 38 Posts
That Guy
Okay guys, i snagged a pair of side view mirrors, with the run signals. I want to install them in the trep. To be honest i don't really care for all of the features besides the turn signals, and power to move the mirrors. Thats all I want, now I can guess that the power in my trep to my mirrors are probably the same colors. I would like to know how to get power to the mirrors and which wire would be the actual turn signal. I planned on running wires from the mirror to my turn signals in the front to accomplish this.
long story and a tad confusing but all I want is power mirrors, which wires i use from the harness, and well any advice pictures. I can post pictures of what wires I have if that helps.
Btw I plastidiped the mirrors vs getting them painted, pretty cool looking if you ask me.:thanks:
Driver Power Mirror (Memory) - White 12-Way
1. Z1 20BK Ground
2. P73 20YL/PK Driver mirror common driver (right/down) C301-14
3. C16 20LB/YL Fused rear window defogger relay output C301-2
4. P71 20YL Driver mirror up driver C301-12
5. P75 20BK/WT Driver mirror left driver C301-13
6. P161 20GY/LB Driver mirror sensor 5V Supply C301-16
7. P64 20YL/OR Driver mirror vertical position signal C301-9
8. P112 18TN/OR Auto day night mirror (+) C300-20
9. P65 20DB/YL Driver mirror horizontal position Signal C301-10
10. P69 20WT/RD Driver mirror sensor ground C301-11
11. P114 18TN/WT Auto day night mirror (-) C300-23
12. L61 18LG Left turn signal (300M Special) C300-24
Passenger Power Mirror (Memory) - Natural 10-Way
1. Z1 20BK Ground
2. P70 20WT Passenger mirror common driver(right/down) C303-5
3. C16 20LB/YL Fused rear window defogger relay output C303-2
4. P72 20YL/BK Passenger mirror up driver C303-4
5. P74 20DB Passenger mirror left driver C303-6
6. P162 20GY/WT Passenger mirror sensor 5V supply C303-16
7. P67 20YL/RD Passenger mirror vertical position signal C303-9
8. L60 18TN Right turn signal (300M Special) C302-16
9. P68 20DG/RD Passenger mirror horizontal position signal C303-10
10. P66 20WT/BK Passenger mirror sensor ground C303-11
That Guy
To figure out which wire is witch do I count top to bottom or what I'm still a tad confused. Like the diagram doesn't quite make sense. I'm kinda a noob to this stuff lol
Download the '02 FSM. It has a section with sketches and pinouts for all connectors. Section 8W-80. Connector locations shown in 8W-91.
That Guy
Totally forgot about the trunk gasket for your Concorde are you still interested if I can get better photos for you?
That Guy
So when I go to put the wire I am using to make the connection to the turn signal in the front to the turn signal in the mirror I get a whole lot of nothing. Like I am confused do I have to have a fuse in or is there a harness that needs to be plugged in I am confused help please :3
Ok sorry forgot to get back to you on this...Here is the wiring for the signals according to the FSM
Driver side: Light green wire
From Mirror connector Pin #12 goes to C300 Pin #24
(C300 is the Harness between door and body of car) Most likely you will have to add wire here or run one around it.
From C300 P#24 to Junction block C6 Pin #11 (according to FSM it just splices into this.)
Passenger side: Tan
From Mirror connector Pin #8 goes to C302 pin #16 (you will have to do the same as C300)
From C302 to Junction block C6 Pin #10
This splices them into your rear signals so if they aren't working at this point I would be checking the bulbs in the Mirrors.
How are you wiring the turn signal from the mirror to the interior of the car? Just running individual wires through the door connector? Which wires have you run to the mirror and where did you connect them inside the car?
That Guy
Discussion Starter #19
So I have the mirrors powered, which ever wires go to the mirror that power it off hand I don't remember. Anyway, I attached a wire to the drivers side turn signal wire which is like green, and ran the wire directly to my front signal and I got nothing. In theory I should have gotten some sort of response correct? Did this on both sides and got nothing, I also tried tapping into the body harness and still nothing. I have the stock body harness for my intrepid, so not sure if that's the issue or I'm just ignorant.
Once again I thank you all for your help ahead of time :)
1 - 20 of 38 Posts
