1 - 11 of 11 Posts
alright so i cant come to a decision so i thought i would ask the wonderful people at DI so i want to put some new rims on the trep and i found these cool charger rims for $300 and these dodge avenger wheels for $100 i will post pictures of them in abit but which ones should i get? and is there a difference in handling or anything when you put different rims on
yeah i do like the look of the charger but i kind of like the avenger better my mom has one so ill probably go with those and my only thing was arent avenger rims smaller than intrepids
1st Gen FTW - It's AutoMedic!
Seriously, how are you going to drive it that you would honestly push the car beyond any spec that the Avenger would cover? Find one you like the look of, and drive happy.
What size tires are on your car, and what size are on the Avenger?
IIRC this topic was brought up about a year ago, maybe 2, and it turned out that the hub bore for the Avenger wheels was smaller than the LH bore, so they won't fit. Same bolt pattern, but different hub bore
Sent from AutoGuide.com App
Heh, then again, if they don't fit, NEVER MIND!
A machine shop charged me 20 each to do a set of steel wheels once for a truck. You could likely do it with a die grinder and a stone, or a Dremel with a stone.
1 - 11 of 11 Posts
