21 - 40 of 40 Posts
Discussion Starter · #21 ·
I only have to use a 1997 flex plate to get a crankshaft position sensor signal. We had the same flex plate for both platforms, even though the transmission and engines are both different. A sensor bolted to the AT bell housing counts windows on the flexplate.
41319
The 1998- 2007 flexplate has a symmetrical bolt pattern and the older flexplate we share with LH has one hole off-centered and D shaped. My 1997 has this older flexplate from the factory, Rock Auto is incorrect on years.
I'll have to dig up some more FSMs to figure out the camshafts, I have the manuals for a bunch of random chryslers but the site I used to get them from is down atm. Might need to just start tearing things down at the salvage yard to find differences.
I have all the LH FSM's in paperback, (Though currently in storage.) I used to have some FSM info on 2004 and later Chrysler products on CD and DVD from Chrysler. Though, I don't currently know where they are at. Somewhere in the basement for sure. I'm sure that info on CS, RS and RT bodies is in amongst those discs. Good hunting for those parts. I haven't had much opportunity to get to a boneyard for years now.
Discussion Starter · #23 ·
Got motor #1, a 4.0L out of a 2010 Chrysler Town and Country. Complete engine with accessories and most of the wiring, sans exhaust manifolds that someone had already taken.
I'm going to try to pull my 3.3L this week so I can set the 4.0 in there and see what I'm working with space-wise. I have hand surgery tomorrow, hopefully that doesn't slow me down too much.
Next I need to go pull a 1st gen Intrepid 3.5L and wiring harness, then I can figure out what needs to be swapped onto the 4 liter to make it compatible with the intrepid EFI.
Once I have both engines in front of me, and become more familiar with them, I promise to go look at some Dodge Nitro 4.0L engines and see if the motor mount bosses on the block look compatible with the LH Platform 3.5. If that's the case, it might be a viable swap for 1st or 2nd gen Intrepids too.
41331
41332
41333
41334
41335
:cool::cool:🤓🤓
Discussion Starter · #24 ·
There is a 1994 3.5L Intrepid at a salvage yard near me, I'm wondering if I should go pull the front harness and PCM from this to begin fabricating a new harness, until I can get hands on a 96-97 PCM?
I think I need to try to stick with the transverse timing cover and upper intake if possible, there is a significant difference in packaging between tall/narrow transverse applications and short/wide longitudinal applications.
I'll need to get the 1st gen Intrepid throttle body I think, and adapt it to the 4.0 manifold.
I know I need the left(front) camshaft sprocket. Hopefully I can come up with a solution to make a hybrid cam sprocket, rather than swapping the entire top end from a 1st gen.
What other stuff do I need to obtain? Coolant sensor, IAT, EGR system, knock sensor, map sensor, ignition coils. Anything I'm missing?
Discussion Starter · #25 ·
I found a couple of engines half ripped out of LX cars. The right motor mount definitely looks compatible with the 4.0 block, I couldn't get any good looks at the left motor mount. The front motor mount would be easy for y'all to get rid of, it just bolts to the timing cover. I imagine, if any of the longitudinal accessories didn't fit, a timing cover swap would fix it.
41343
41344
Somebody post some pictures of a longitudinal 3.5, we can compare blocks and see if the mounts will bolt to a 4.0 block. I know the oil filter location is different, it's under the harmonic balancer on the transverse block but on the left side of the longitudinal block.
41TE: 3.3L vs SOHC bolt holes
41345
I've got a full gasket set and timing kit. I'm going to order an Inertia Motorsports V1.2 camshaft set and Megasquirt MS3X tomorrow. Teardown this weekend to see how the bearings, rings, and such look. I did a compression check and got 158-162 psi across all the cylinders. Interestingly, I cranked the 4.0 over with a 1997 41te case, the 2004+ NGC flexplate, and a 3.3L/41te starter. Seems Chrysler has been very lazy about changing dimensions over the years.
The 3.3L and 3.5L are so damn similar, Im going to just hook up the 3.3L pcm to the 4.0L with SBEC sensors, minus the injectors and ignition, then piggyback the MS3X to run the actual fuel and timing. This should keep my TCM, BCM, and instrument cluster happy, plus give me some tunability to get the most out of the cammed motor.
Discussion Starter · #26 ·
The bottom end is ridiculous. I knew they upsized the main bearing journal diameter for "NVH" reasons. The windage tray is a 1/2 inch thick structural piece of cast aluminum, it's bolted in with the outer main bearing caps bolts. Not sure which engines got this, it looks like some 3.5's have the structural windage tray, while others got a steel windage tray.
Cross bolts on all 4 main bearing caps, I think all the aluminum 3.5's got this, or else it was only the two middle caps that are crossbolted?
41351
41352
41353
Oh god, someone worked on this motor at some point, and used silicone to attach the lower manifold. Every single intake port had this blob of silicone growing into the port🤮
41354
Here's the left side, now that I have the accessories striped off. Pretty sure those 3 angled holes are for a Longitudinal engine mount? One is half hidden behind the dipstick tube hole, swapping the pan would fix that.
41355
Gotta go buy a claw gear puller today to get the harmonic balancer off. Then I can pull the timing and heads.
41356
I tried to buy the V1.2 Camshafts from Inertia Motorsports, their website is down at the moment? They had just emailed me back on the 7th with an answer to a question. Maybe I'll try emailing them again...
Discussion Starter · #28 · (Edited)
Ive received the Megasquirt MS3X and Wiring Harness. The block and crank are at a machine shop, I had some ugly bearings. Whoever worked on this motor had the rear bank camshaft off by one timing mark, and the tensioner puller loose.
Inertia Motorsports V1.2 Camshafts were ordered a week and a half ago, they are on their way from Crower.
Going to tear the old 3.3L out this weekend. I'll start porting, polishing, and lapping valves next week.
Here is the problem with the timing sprockets-
NGC(2nd gen LH/LX/RT platform) camshaft sprocket-
41403
SBEC(1st gen LH) Camshaft Sprocket-
41404
NGC camshaft keying
41405
SBEC Camshaft Keying
41406
And, the solution. The timing wheel is just a thin piece of sheet metal interference fit onto the sprocket. Hit it with a little heat from a torch, and it will pop right off.
41407
SBEC Ring, all 4 tabs are the same size.
41408
NGC Ring, the tab near the TDC timing notch is wider
41409
And the SBEC Ring installed on the NGC Sprocket, a 10 minute job.
41410
Discussion Starter · #30 ·
Got the block and crankshaft back from the machine shop. The bearings were ugly as were the journals. They turned the crankshaft 0.010" under on the rod and main journals. Got the cylinders honed, they looked pretty good beforehand. I should have the new bearing set next week.
Still waiting on the V1.2 camshafts.
I need to order new rings, put some serious scrubbing in on the pistons with brass brushes.
41434
Started tearing into the cylinder heads. There are valve marks on all the pistons and the heads looked incredibly clean, I found some scribing on the heads from 2017. I think this engine must of thrown the timing belt, and had the heads replaced.
41435
After cleaning up
41436
After polishing the combustion chamber. One down, 5 to go.
41437
I'm also going to polish the intake/exhaust ports and runners. Casting flash is almost non-existent. The lower manifold and intake runners are perfectly port matched from the factory as far as my eye can see, but the exhaust ports need to be opened up ~1/16" to match the headers. Definitely need to get these heads decked when I'm done, having them dipped probably won't hurt either after all my grinding and sanding.
Discussion Starter · #31 ·
Ive gotten sidetracked a little bit-
41444
I bought the complete AWD system out of a 2000 Town And Country.
41445
41446
Still have to bolt the differential, driveshaft, and CV axles in, but the rear beam axle, brake lines, hubs, and leaf springs are in. I'll bolt up the PTU to the transmission while I have it out, I've already verified that it bolts to the 4.0L block.
41447
I've got the block and crank back, piston rings, paint, and gaskets. I'll pick up the new rod, main, and thrust bearings tomorrow and start assembly.
Headwork, I've only managed to polish three combustion chambers, I'll do the other 3 tonight. Still need to port the heads and lower intake manifold after that. The Inertia Motorsports Camshafts should be here soon.
41448
Discussion Starter · #32 ·
Well, I haven't had much time to get stuff done, Ive been working ridiculous hours and have had to put some wrench time into my beater('99 VW Jetta) that I am driving while the van is down.
The Inertia Motorsports V1.2 Camshafts arrived last month from Crower, they're sitting with everything else ready to assemble. New rings, new 0.010" under rod and main bearings, new crankshaft thrust bearings, new oil pump, new timing belt kit, new coolant pump.
I think I'm going to take the block and have it soda blasted before painting, the shop that worked the block sprayed a very poorly prepped coat of silver paint onto the block that flakes off with compressed air, and they oversprayed a lot. I had them re"hot-tank" the block, but since aluminum can only be dipped in hot soap water instead of acid like steel, it did little to remove their paint.
I did prime and paint a few parts. I think the black and Hemi Racing Orange will look fantastic.
41613
41614
Oh, and I gave up on porting my heads. Blame it on ADHD maybe, it is so much work. I payed for a set of big valve/ CNC ported heads from Inertia Motorsports, hopefully they're here in about two months. Debating if I should even put this bottom end back together; If I got some fancy pistons and rods to lower compression, a Whipple 140ax wouldnt have to work hard to run 1 bar of boost.:unsure: I'd have to source a T-850 5 Speed transmission, I think my A604 can handle ~300HP/~300ft/lbs, but 450, 500, more? I'm sure it'd snap the scrawny input shaft or turn the clutches into paste.
Yikes, here's the input shaft from the TC on my transmission...
Sensitive content, not recommended for those under 18
Show Content
41615
on the dyno, my 4.0 stroker gets 168hp to the wheels......... :love:
i think you need to use the long block from your generation, and put the internals into it. there are mounting bolts, and exterior differences that will make a conversion rough.
sounds like you understand that, might take time to part-and-piece the brackets you need.
Discussion Starter · #36 ·
Finally had some time to tinker with car projects. I sodablasted the block, then primed and painted the heads and block.
Tomorrow I'm going to put the crank in with some new bearings, and try to get the Pistons in.
Tire Wheel Vehicle Automotive lighting Automotive tire
Tire Wheel Automotive tire Light Automotive lighting
Tire Motor vehicle Automotive tire Hood Tread
Tire Hood Motor vehicle Plant Automotive tire
Tire Wheel Automotive tire Motor vehicle Hood
Discussion Starter · #37 ·
I got the bottom end together, and the heads on. New rings and bearings, everything plasti-gauged in spec and is torqued to spec.
Automotive tire Motor vehicle Bumper Automotive exterior Electrical wiring
Hood Automotive tire Motor vehicle Automotive design Automotive exterior
Motor vehicle Automotive engine gasket Automotive tire Engineering Gas
Motor vehicle Automotive tire Automotive exterior Engineering Gas
Here's the Inertia Motorsports 1.2 heads, with the oversized stainless steel valves and CNC ported. I'm not sure what the valve springs are, but they have Crower retainers on them.
Automotive tire Wheel Light Motor vehicle Automotive design
Automotive design Engineering Motor vehicle Auto part Machine
Got the Crower Cams from Inertia Motorsports with the V1.2 grind installed. Went into the heads smooth as silk.
I slapped the intake, valve covers, oil pan, and headers on to seal it up until I can wrench on it again, probably also to see its beauty.
Motor vehicle Wheel Automotive tire Automotive exterior Gas
I've got to find where I set my "custom" camshaft sprocket/timing wheel. I also need to drill out the crankshaft timing wheel sprocket pin/key so I can replace it. It mushroomed flat with barely any tapping, so I filed it flat to get the oil pump on. I've tried several styles of punches but can't seem to move it. Then I can set the timing.
Lastly, I've got the issue of a couple lash adjusters(lifters) that have cracked plastic retainers. I think I want to just replace all the lifters, but Im finding mixed information on the internet. The FSM says not to replace lifters, only entire rocker arms. Lifters are available online, and some posts here say they're easily replaced, but I'm not 100% confident until I try. Any advice?
Discussion Starter · #38 ·
I ordered a set of Triumph 675 Daytona motorcycle throttle bodies, it's a three cylinder bike. If I decide they look up to the task, I'll order a second set.
Plan is to throw the 4.0L intake into the trash where it belongs, have a machinist fabricate an upper intake, and run six independent throttle bodies. Maybe easier than figuring out the drive by wire TB on the 4.0 intake, as well as the variable length intake runner valves. I also don't really want to swap on a 3.5L intake either. This should give me the best performance, even if it's not the "Simplist" solution.
Throttle Bodies should be here this week, plus I've got a crankshaft pin coming to get the crankshaft timing sprocket sorted out. Still need to decide what to do with the rockers/lifters.
Discussion Starter · #39 ·
I got the Crankshaft pin fixed. I couldn't get it out, but I felt pretty confident and drilled it out. Started with a really small drill bit and was able to look inside the front of the crankshaft and verify that the bit was coming outcentered in the hole. Stepped up the bit size and maybe 1/32 before the actual diameter of the pin the thin shell fell out. Tapped a new key/pin in and got the timing set. I had put the engine at TDC according to the #1 piston, looks like my pin is pretty close.
Automotive tire Motor vehicle Rim Gas Auto part
While this is the last image, Im thinking that this may be the best place to put a toothed sprocket(with one tooth missing) for timing the Megasquirt ECU. I'd have to machine out the center hole to get it to fit over the crank, but after that I'd have two convenient threaded holes to bolt it to the crankshaft sprocket. Alternatively, I'll have to bolt it the the front of the harmonic balancer, which presents two different issues. The harmonic balancer isn't actually keyed, only press fit, and there's no convenient spot on the harmonic balancer to run radially placed bolts to keep the toothed sprocket fixed to the harmonic balancer.
I also need to decide which cam sprocket to place a toothed wheel onto, much easier to fabricate a new timing wheel than try to decide my SBEC signals.
Here's the timing belt done:
Motor vehicle Automotive tire Automotive design Engineering Machine
I have the oil pan torqued to spec, and everything in the timing cover. My gasket set is missing some seal for the oil cooler and oil filter bracket, gonna need to order those.
I still haven't figured out how to get the old lifters out of the rocker arms, even though I have 24 new lifters(lash adjusters) on hand. I may just try to find a pretty set of rocker arms out of a 3.5L at the junkyard.
Got the Triumph motorcycle throttle bodies. Unsurprisingly, the bore spacing is much closer than a bank of cylinders on the Chrysler V6. I'll probably have the intake runners bent slightly to fit the throttle bodies, rather than try to space out the throttle bodies and make the linkages work.
Motor vehicle Automotive lighting Machine Personal protective equipment Automotive design
Motor vehicle Gas Automotive lighting Machine Engineering
I disassembled them and ran them through my wet tumbler I use for brass ammo cases. The one on the left is how they came, the one on the right is after wet tumbling with stainless steel pins.
Automotive tire Motor vehicle Rim Gas Automotive lighting
Automotive tire Motor vehicle Automotive design Bicycle part Gas
I have another set of throttle bodies coming. I'll need to sketch the manifold in 3D CAD for my machinist, then set him to work on it.
Discussion Starter · #40 ·
Alright, update finally.
I designed some timing sprockets, 3D printed them to test, and then scraped them when I figured out I could use "2000 Jeep" in the MegaSquirt software. Apparently, the 2000 Jeep 4.0's had the same SBEC timing windows cut into their flex plate/flywheel as my 97 Plymouth, and a 50/50 single toothed Cam sprocket. So, all I need to do is put a 50/50 cam sprocket onto my engine, piggyback the crankshaft sensor signal, and I'll be good to go.
Here's the original 36-1 tooth sprocket I 3D printed
Crankset Automotive tire Gear Rim Bicycle part
And the toothed section of the new 50/50 tooth, there's two parts that bolt together.
Head Eye Font Circle Pattern
I'm waiting on SendCutSend to send me the parts laser cut.
Otherwise, I'm still brainstorming the intake manifold. I have the flange drawn up in 3D software, but I need to figure out how to route the coolant system. I think the head gaskets only allow coolant to flow through at the back of the head. This means the coolant pump pushes coolant into the front of the block, the coolant goes through the block to the back of the block, then the coolant flows up into the head, and then the coolant flows through the head to the front of the cylinder head where it exits into the intake manifold.
I designed this flange, it has 25mm holes over the coolant ports, which are the exact size to tap for -12AN hose fittings. My current idea is to have this cut out of 1/2" aluminum, with a thinner plate underneath port matching the coolant ports in the head to the flange with 12an fittings. Then, the ITB runners can be welded onto the 1/2" flange and the coolant hoses will run to a coolant manifold like V8 guys with crazy intakes use.
12AN Flange
Automotive tire Font Automotive exterior Wood Rectangle
And the normal flange
Automotive tire Grille Automotive lighting Rectangle Hood
Ideally, I would pull the heads off, cut holes in the head gaskets to flow coolant from the center cylinder into the head, and run all 4 coolant ports on the heads, but for now I think I'll just stick with the two on the front of the heads.
Finally, engine as it's sitting now.
Motor vehicle Automotive tire Automotive design Automotive exterior Engineering
I found some 2005 or 2006 aluminum valve covers on a Charger. They have the same Coil on Plugs as the later plastic cover 3.5's but are actually aluminum. Painted them black, I need to order gaskets for them as they're different from the plastic valve cover gaskets.
21 - 40 of 40 Posts
