1 - 2 of 2 Posts
I have a jeep liberty that I have been working on.
The valve body seems to be an issue when working on your back, both removing and installing.
I just want to share a tip I used working by myself.
I went to Ace hardware , in their specialty bolt trays they carry 6 inch all these rods, metric.
Buy four rods with flat washers and nuts.
Screw the rods into the four locations were the hex bolts were and run the washers and nuts up on the rods.
Now you have jacking bolts to reinstall the valve body and can position the accumulator pistons by yourself.
They also allow you to remove the valve body slowly.
Hope this helps someone.
Fortunately I never had to work on the valve body, but have read a few threads on the great fun people have had with it.
That sounds like a good tip!
1 - 2 of 2 Posts
