I'm using Firefox-Some threads will have member-posted pics, and all I see is an underscore line..
Anyone know why?
I see that the HTML enable is off-- do I need that 'on', and how do i accomplish that?
In regards to the pics you can't see using Firefox, can you see them using another browser? I ask because sometimes the server hosting the pic may get a hiccup or be down or something.
Also, where do you see HTML is off? On the forum boards? If so, that is set by the admin and there is nothing you can do about it.
Anyone know why?
In Options under the Content tab, do you have the "Load Pictures' box checked? You should. If so, do you have the 'From Originating Site Only Checked'? This will keep FF from loading pix from a site other than the one you are on, like offsite photo hosting. Uncheck it if you do.
The enable HTML code is a forum setting that would allow posters to use HTML coding to format posts and signatures. Most forums shut it off because there is usually someone that goes too far with it and just pisses everyone else off. It has no effect on you viewing any pix and only forum admins can enable it. (I see that was already answered)
Thanks, everyone!
I'll do the options reset.
