Just like the title says.
Got a fraternity brother with a 1975 AMC 258 with the 4.2L I6.
Problem is, it won't start.
It will turn over, but no ignition of the fuel.
He has tested all of the following:
Fuel Test
Fuel Pressure
Spark
Compression
Timing
Battery Voltage
Ground/Power Cables
He has replaced literally every piece of the ignition system from what he said.
Still, no go.
It ran fine until a couple of months ago, then just wouldnt start one morning. Has never been able to figure out why.
Any ideas from the great minds here?
Fuel Test
Fuel Pressure
Spark
Compression
Timing
Battery Voltage
Ground/Power Cables
Still, no go.
