I just purchased a set of 9011 bulbs for my wifes car and what a difference !
The high beams give you far greater distance and width.:sohappy:
I purchased these Philips bulbs on Amazon for $18 each.
I've been experimenting with 9005's for the low beams and the
jury's still out if their a little too bright.
Any pictures? Are the bases the same?
The 9011 requires one tab to be trimmed slightly , other wise the
diameter for the o-ring seal is the same . The 9011 is rated for
2350 Lumens vs. 1700 for a 9005. Both are 65 watt.
The 9005 for lows also requires some tab trimming and the diameter
for the o-ring seal is smaller. You could buy a thicker o-ring or just wrap
the o-ring area with some narrowed electrical tape and then install the
o-ring. 9005-1700 ,,, 9006 - 1000 Lumens.
A 9012 for low beams is the same diameter. Not sure of the Lumens.
Sorry , no pictures.
