Hello i'am looking into get a 94 newyorker for part's for my 97 vision it has a few problem's, it's stuck in sec gear speedo don't work, gas gage, nor does the temp, but the check engine light is not on, all else is fine car only has 130.000km for 1500$ cnd, any idea's what could be wrong with it, any info is good info. Thx's
Check for codes, and I'd bet if you changed the Input and Output Sensor's on the tranny you'll get your speedo back and you can get out of second gear. Has for your temp gauge look into the Coolant Temp Sensor.
The 1994 LHs is OBDI and your car is OBDII . So you can't use all the TCM,PCM or BCM coming from the 1994 car.
