my friend has a 94 tbird and the check engine light comes on and off all the time anyone know how to run a diagnosis on a ford vehicle of this age? we saw one thing about opening an ecc connector and then you use a "jumper wire" to certain connectors that enables the engline light code flash... any ideas/incite?
get off my lawn
yea,, the jump wire trick dont work so well on fords,, find a auto zone and let them pull the codes for you
last time i was at autozone trying to get them to put a scanner in my trep they said cali has outlawed it now unless you mean they could easily get the jumper way?
yea :glum: think were still going to try and take it over their and see if they can at least help us with the jumper then
