1 - 1 of 1 Posts
I recently replaced my ignition lock cylinder. I had it drilled out before and it started with a screw driver up until the last time I attempted to start it with a screwdriver, which everything would seem alright, then I would turn the key to start and all the lights flash off, but no sound, other than some clicking under the hood. I swapped some of the relay's without any change to my issue. I even tried jumping my car and let it charge for 10 minutes.
When I have the key in the run position the radio doesn't work, nor do the windows. The radio does work with the key in the aux position. Any suggestions would be welcome.
1 - 1 of 1 Posts
