1 - 2 of 2 Posts
alrighty i just refinished my headlights with a kit from advanced auto, and it worked great, but i need to replace my bulbs, and i can figure out how to do that to save my life.......so if anyone could shed some light on the subject i would appreciate it...
well, you are suposed to be able to remove the two torx head screws that hold the headlight housing in the bracket. Then you just twist the retainer on the bulb, and pull the bulb out. However, my experiance is that those torx head bolts do not like to come out wihout breaking things. This leaves two options that I have used. One is to get one of the screws to come out, and pivot the housing on the other screw and scrape your hand to peices trying to get the bulb switched out. The other option is to remove the front bumper(not really that hard) and take the entire headlight bracket off to replace the bulb. Hope thise helps.
-Taaf-
1 - 2 of 2 Posts
