99 dodge intrepid 2.7L
Cranks but no start. Fuel pump engages and pressurizes, new crank shaft sensor, good starter, New Radiator, New coolant output, Heads are not blown, timing not jumped. I need any ideas on where to go from here. any information or help would be greatly appreciated.
fuses good? since the starter relay is good, switch it with the asd relay. then check for power at the coils and injectors to start.
Also check for engine sensor power at any sensor (the sensors share a common 5 volt sensor power bus. Also try disconnecting the cam position sensor to see if it will start (it will run below 2500 rpm without the cam position sensor, and sometimes a failed cam sensor will pull down the sensor power bus).
