'99 Intrepid climate fan motor resistor in a '97 Intrepid...?
1063 Views 4 Replies 5 Participants Last post by  GTXKen
6
Hi, I'm replacing a bad climate fan motor resistor in my '97 Intrepid. I have an Automatic Climate Control feature. Can I safely use a resistor from a '99 Intrepid in my '97?
Both resistors basically look the same, except, on the '99 one, you can see the circuit board when you look into the connection area.
I've attached some pictures of the resistors side by side. The bad resistor in the one on the right.
Any advice is greatly appreciated.
Thanks.
See less See more
well i just looked up blower motor resistor for the 99 and 97 intrepid. they had the same part # at auto zone. 97 link on top 99 link on the bottom
http://www.autozone.com/autozone/pa.../N-jjlh6Z91tag?itemIdentifier=119776_0_0_5396
http://www.autozone.com/autozone/pa...icleIdForService=334201063&_requestid=1079986
hope this helps you out
Interesting. I'd say go for it!
$221 for those at Vatozone! Wonder what the dealer charges?
why a new thread?
they are interchangeable. as shown in the link of your other thread.
Keep an eye on things. You may have a blower motor going south which can cause the resistor to overheat and burn out.
Thats one of the items I pick up when I'm at the pick and pull regardless of I have a current need or not
