hello, i get up this morning and go out to warm the trep up and nothing! it will turn over for days but wont start. if i keep my foot on the gas and start it it will start but run very bad. once i let my foot off the gas it will stall out.
if you gave my a old motor with no computer stuff and this and that i could go at it. but is there somewhere i can start? i really dont want to have it towed and end up being something simple or common.
i thank you for any help you can give me. im not going anywhere !!!
Pickle
"if i keep my foot on the gas and start it it will start but run very bad. once i let my foot off the gas it will stall out."
Could you explain the above statement a little further. Is it making any clunking/loud noises when you do get it running? What size motor? (2.7, 3.2?) How many miles?
You should be able to get codes from it...do a search on here for checking codes...
Has it been out in the freezing cold? Perhaps some moisture frozen in the fuel line or tank.
