1 - 11 of 11 Posts
My a/c isn't working. If I take off the belt will its removal affect anything else?
p.s. Moparfest August 19 & 20 2006 Newhamburg Ont. (1hr west of Toronto)
http://www.moparfest.com/Directions.html
what size engine? isn't the 3.3's all one belt, where as the 3.5 has a seperate belt for the a/c, correct me if I'm wrong
Discussion Starter · #7 ·
Thanks everyone for the help, and yes the belt only attaches to the A/C compressor.
3.3 and 3.5 have a seperate belt for the A/C. It only goes from the crank, to the idler pulley, and then to the compressor.
95Intrepisize said:
No it won't effect anything else. But good luck getting it back on. Only take it off if your set on giving a day to put it back together.
so is it really that hard? thats my project for next weekend.
I don't agree. If a 3.5 you simply loosten the idler for the serpentine and off it comes. Loosten the idler for the A/C, from the bottom, and reinstall the belt. Tighten the idler. Replace the serpentine and tighten it's idler. If it takes more than 1/2 hour then there's something wrong.
If you simply want to remove the belt and never use it again, just cut it.
yea, that's what I was gonna say, if the compressor is fubar, just cut the damn belt, you have no use for it
1 - 11 of 11 Posts
