After replacing everything on my A/C system (except for the evaporator) with new parts, I pulled a vacuum for about an hour and a half down to nearly -30 psi. I then let it sit for another 3 hours to see if it lost any vacuum. It didn't budge. I thought I was set so I filled it with the specified amount of refrigerant. The air blew really cold, and I was really enjoying it. The next day, no more cold air. Obviously, there is a leak. Under vacuum, no leak. Under pressure, refrigerant leaks. Which leaves me with the following questions:
1. After finding and fixing the leak, I will vacuum again and recharge. Will this remove the PAG oil (I was under the impression that vacuuming wouldn't, but I've seen conflicting information)?
2. Presuming that vacuuming the system doesn't draw any of the PAG oil out of the system, would it have evaporated from being exposed to the outside air through the leak? I'm really not looking forward to removing the compressor, draining the oil, and then filling it with the proper amount; but I do not want a compressor failure either.
Any suggestions are appreciated, especially if there are other factors which I have failed to consider.
