ok, i have to pull my struts because i didn't replace one part in em when i did the job. as many of you know, i have what seems like a fuel issue. starts rough and dies after sitting. this also affects my driving at 45-50mph where it feels like a little bucking. at one point i thought it might be a cv axle.
i did not check this when struts out last time, but when i turn the wheel bearing (struts are still off the car. rotors are off) there is a feeling of "gear lash" on the passenger side only. neighbor says coming from the diffy, and not bearing or cv joint. it isnt bad, but it is noticeable. the drivers side does not do this-it is smooth-both turn with about the same force and there is no play in the axle shaft or the bearing. is this normal? i changed out the diffy fluid about 15k ago but the car has always had this problem.
