Hey,
Is there any way to add ABS and traction control to an SE that did not have it factory.
if it doesn't have ABS already it could be costly to do as you will have to add all the sensors and wiring to the sensors. no IF your car has ABS already all you would need is an ABS/Trac control pump from one that has it and install it on your car other will chime in though I'm sure there are a few other things you'd need to do I believe there is a how to on this try looking it up it may help you
You need to add the 4 sensors, 2 new rear wheel bearings with tone rings, new CV shafts with tone rings, body harness with wiring, engine harness from a car with abs/track, new master cylinder, some new brake lines and the module itself. It's totally possible with some $$ and some work.
