So, I had a look at the fuses again and sometimes they aren't always easy to tell if broken. But, sure enough, the 40A ABS pump fuse under the hood was blown. I put a new one in and it popped almost as soon as I tested the ABS.
So it seems like the ABS pump is the issue. The actuators and valves work fine when I test them with my scan tool, they open and close no problem. My brake fluid is clean and there is no air in the system. Its the pump that is blowing the fuse when activated. I am wondering if I have a broken wire somewhere or if the pump itself is dead. Can I just get a scrap ABS module and take off the pump, I believe there are two screws securing it to the Hydraulic unit, and then swap it in for my broken one? It seems this would be a possible fix. Or, its an electrical issue, which sounds like fun....
I have always been a bit of a parts changer, I can do a lot, but diagnostics, especially electrical problems are not my cup of tea...
